Interesting OEM 522 Whippled EFI engine build.
#41
Balancer installed. Long block complete.
Trident will supply everything from here. I will be happy to install it.
![](http://www.hotboat.com/image_center/data/520/2112done-med.jpg)
#42
Trident engine #2 ready to start.
Completely machined Merlin III block. Ready to fit piston rings and assemble.
![](http://www.hotboat.com/image_center/data/520/211merlin3-med.jpg)
#43
I have been behind posting the Trident engine build. Here is a little that will catch up some.
Getting ready to send two engines to Trident. Will dyno them with the blower and fuel injection systems in a few weeks at Gary Teague's place.
I wanted to warm them up, leak check and retorque everything before shipping. I do not have the blower, valve covers, ignition or fuel systems that will be installed on them in the boat so I warmed them up N/A with some stuff I had lying around.
They will have custom valve covers, A Whipple intercooled 3.3 and MEFI 4 based EFI system. What is on it in the video will do just to get some heat in it so I can look things over.
Ran the water hose to a "Y" valve and used a 160 degree thermostat. When the thermostat opens it just duimps out at a #8 hose rate.
Pretty nasty sounding 7.7:1 family boat engine. The blower will smooth it out a bit. Maybe I cheated a little with the fuel mixture to make it sound healthier? Nah !!
Short Warm Up Video
Short Warm Up Video
#44
Well those red X's were nice huh? I cannot edit my posts.
i was on a coopy - paste roll. should have stopped and looked.
Let me try those again.
#45
As Always "Info" your attention to detail and procedures
are Top Shelf
Gerry
are Top Shelf
![Drink](/forums/images/smilies/drink.gif)
Gerry
#46
Lets try this again.
Will be fairly direct and to the point to finish this project up.
Dooley supplied pan pick up.
![](http://www.riverratlife.com/uploads/info/Pickup.jpg)
