Exhaust Flapper question
Charter Member #139 /Moderator/Platinum Member
I nm adding CMI headers with Cmi tailpipes and Livorsi Bandit mufflers as far as I can see there is no flapper in these parts whare should it be or do I need the external rubber kind I am pretty flapper iliterate
bump
Kept the Bullet and the condo and joined the cig 20 restoration club.
Use the external rubber model. When you are shut down enjoying some sun or lunch there is always somebody running a wake into your transom. Without the flapper you get an engine full of water.
