525SC Specs
Charter Member #737
I need and info, specs pics of a 525SC. I am building a copy of one and any info would help.
Charter Member #737
Anything and everything. I am building one.
454, 7.5:1 CR, forged crank & internals, rectangular port heads, roller rockers, hydraulic cam (dont have specs on me) 2.25/1.88 valves, 177 weiand blower, 5 psi, gil exhaust, Tbolt IV ignition. That's all that comes to mind.
Gary
Gary
The cam is a Crane #132561
Specs are 228/236 .530/.551 on a 114 lobe sep.
The ignition timing curve is set up with 13* base timing and 22* advance. It advances to 25* by 2000rpms and then gradually advances up to full advance of 35* by 4500rpms.
Carb is a 1050 dominator
Jets are 98's all around--I think(Holley #122-98)
6.5 PV's front & back
#35 Acelerator nozzles
50cc acc pumps front & back
Acc pump cams-frt& rear--white-use # 1 hole.
Boost is set at 5.5# stock with a 2:1 ratio
Pistons are forged TRW #L2453
Valves are 2.19/1.88
Charter Member #737
Thanks guys
Charter Member #737
ttt
speel chekk this fokker!
i had a copy biult and havebeen very happy iwth it. I'm kaing 550 with my setup.
if you want eth build sheet i'll gladly scan and post it!
Pardon me, while I whip this out!
Charter Member #737
Puder that would be great.
