diminsions of alignment tool???
First two and a quarter inches is one inch in diameter.
Second two and a quarter inches is one and three sixteenths inches in diameter. The rest (17 1/2") is one and three eighths inches in diameter. Now get out there and save a couple bucks.
Ginger or Mary Ann?
Mine measures 1.010" also. That is my Merc tool.
Just a tip:
I made a couple of stubbies 1.010 and 1.000, along with a new tool at 1.000
I use the stubbies to see if the alignment tool will even go in the coupler. They are only a couple inches long and checked for fitting by reaching over the back of the motor. IF the standard 1.010 does not go in, then i check with the 1.000. If that one does not go in, then I check the couple close for wear. If both stubbies do go into the coupler with a good straight, non bell mouthed feel, I can use the undersized alignment tool to get the alignment close if I am having trouble with standard one to work. Then switch to the standard and fine tune.
Just a tip:
Ginger or Mary Ann?
![Wink](/forums/images/smilies/wink.gif)
