Engine done! Need a prop!
I've got a 95 24 Outlaw with around 540 hp and 700 torque. I run a labbed 26" Bravo 1 to 5000 rpm and will do 75 on GPS. I had a Hydromotive but never got any speed out of it. You need a Bravo 1. I would start with a 26" and see where you're revs are. You might then need to go to a 28"
Good Luck
Good Luck
Official OSO boat whore
Just be freekin' carefull. You have to be coming up on the design limit of that hull. If you find chine walking to be a problem, the Q4 Hydromotive will help stabilize the hull. That prop will suck getting on plane. It won't be as bad as a 3 blade Mirage though. The bravo will plane very well and will offer a good top end. I'd try all 3 props.
![Talking](/forums/images/icons/icon10.gif)
Good Luck
Good Luck
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
Guys,
I switched back to my 25 mirage. The hydromotive just wasn't geared for this boat. I am now running 72mph on gps at 5400-5500 rpms. I was wondering if someone had a 27 mirage or a 26 or 28 bravo. I was also wondering what it would cost to rework my prop to fit my needs. My torque peak on the engine was around 4900-5000. Thanks again.
24outlaw, do you want to sell the Hydro 27 ? If so PM me I may be able to use it. I just put my motor in my 25 checkmate and they love Hydro's. We dyno'd it @ 646hp at 5600rpm. Thanks to JimV. We will water test in the AM
I have a 24 outlaw with about 450 hp. I was wondering what the accelerator prop is? I currently have a labbed 24 Bravo 1. I have not been able to go for a top end speed yet because I injured my knee. Last year with a 3 blade mirage 23 with added pitch and cup, I was able to hit 68 on gps. I have since rebuilt the motor and expect some more hp. Just wondering what the accelerator is?
Allen
Allen
