Weird cooling prob >
Weird cooling prob
Weird cooling prob
Old 05-06-2004, 07:13 PM
You can run a ground wire around if you don't have the Merc gasket. Not worth the trouble. Go buy several so you have it next time.
BadDog is offline
Old 05-06-2004, 07:16 PM
blownboat
You should use an ohms meter and see if your sender is grounded before you go pulling it apart.
Old 05-09-2004, 05:19 PM
97BossHammer's Avatar
well i replaced the thermostat gasket.....didn't fix the prob. Wonder what it could be?
97BossHammer is offline
Old 05-09-2004, 11:16 PM
Received 1,938 Likes on 976 Posts
Originally posted by 97BossHammer
ah forgot to mention....did that as well, replaced the sender as well as the tstat.
Bad sender or its not getting good contact with the threads to ground itself.
Griff is offline
sandcraft
10
04-05-2006 09:44 PM
mattis75
1
08-17-2003 07:08 PM
Scarab3DMC
4
06-10-2003 02:08 PM
JUSTONCE
05-20-2003 04:24 PM
JUSTONCE
04-29-2003 05:33 PM
Quick Reply: Weird cooling prob
