Is this price correct for a mech fuel pump
Unfortunately you have to buy the one from Merc. There is no aftermarket pump that I am aware of that will work. That prices sounds right. To double check go to www.mercruiserparts.com He has great pricing on parts.
Jerry B
The front seal started leaking on my sea pump. After removing it I found the lube oil had a gas oder so I replaced the fuel pump and the front seal . Maybe the gas was hard on the front shaft seal also?
