Best trailer wheel bearing grease
Charter Member #34
Originally posted by rv
Dock Holiday,
I can understand your point about the bearing temperatures being below 200deg on a wheel without brakes. What about a wheel that does have brakes, doesn't the brakes cause those bearings to be above 200deg? I understand that when you are making a long trip and the brakes are not on that the temp would be below but what happens around town when you are braking alot. Doesn't the temp go up and exceed the rating of the grease?
Rick
Dock Holiday,
Rick
I run disc brakes and have never seen a temperature even close to 200 degrees on my trailer on the hottest days. Drum brakes may have a different effect on them but it is hard for me to see where you would get temps that high.
Maybe someone else will come in on this with some additional information.
I do know that most High Temp greases do not give you the lubrication you need in the normal operating range.
Dock
Charter Member #34
Re: Citgo JT-6 Multi-Purpose Grease
Originally posted by BenPerfected
I found it on the Citgo website, but where is a easy place to buy a case?
Mystik® JT-6® Multi-Purpose Grease
Our most water-resistant and water insoluble product, JT-6 works especially well where extended lubrication intervals are practical, highly loaded or shock loaded grease lubricated applications exist, and excellent rust protection is desired.
http://www.springboardsandmore.com/d...nt/p-PM111.asp
Call me if you want some, our everyday price is $2.55 per tube, there are 10 tubes per carton. We charge only the actual UPS charges with no handling charges and accept Visa, MasterCard and Amex.
Mark, Randall or Anthony
Allied Bearings & Supply
704-881-0031
Charter Member #601
Hey Mark!!
I did indeed get those bearings.Thanks!!, sorry I didnt let you know. Had a lift rented all week for drywall had to finish up and return it.. Some long days with drywall tiring nights.
I would love to try a tube of the Mystic!! I will try to remember on the next order for sure.. or maybe you could write a note??
I like to try anything that works for someone else... sounds like the Mystic fits.
Thanks!!
Dick
Thanks!!
Dick
This is a repeat of what I said to rv and Dock Holiday:
By the time your wheel bearings get to 200 degrees, they are well on their way to failure. Check axle nut setting by jacking tire off the ground and grabbing tire at top and bottom and wiggling it. Pull on top while pushing on bottom and should have about 1/8 inch wiggle at the tread. Too tight, and bearing gall. Make sure you over tighten the nut first and spin the wheel to seat the bearings in the hub, but then back off the nut for the wiggle test.
Continuing;
Old style grease like Lubriplate will wash out easily and has a low melting temp. It is ok for engine assembly. Mystic has a long slippery molecule. Rub a dab between your thumb and forefinger, you almost can't feel those fingerprint ridges. Squeeze really hard and keep rubbing. Try that with any other grease. Also, it is really hard to wash off with soap and water. Some may remember "Motor Honey" by Andy Grannetelli, this Mystic is just as slippery.
I don't like those fiber based greases, they may be ok for wooden wheels on Ox cart, but not for me.
Two of my boat buddies build and race boats. They swear by Mystic. Always use it on wheel hubs and even on jet ski guts. Won't wash out. Immiscible
It is the only thing we used on 15,000,000 sq ft of buildings where I was the lead engineer.
Mystic is cheap and readily available at car parts places (Auto Zone?) and farm supply stores.
