Engine starts, but immediately stalls
Re: Engine starts, but immediately stalls
Originally Posted by stretchnout
Hey Love Machine,
I this weekend had a similar problem. I ran about 30 min. to get gas and after putting about 100 gallons in went to start the boat and it started but then stalled. After pulling fuel lines checking for blockages I pulled the fuel water seperators and dumped them. Then filled them all the way to the top and reinstalled new filters and turned the key and they both started and ran great. There are 2 fuel pumps one that fills the fuel water seperator that is mech and one that pumps the fuel to the injectors that is the elec pump. Try filling the seperators all the way up if you get a chance..... Good Luck
It's fixed! Re: Engine starts, but immediately stalls
Everyone, thanks for your input. I did fix it myself this past weekend. It ended up being something simple.
I pulled the gas filter and there was hardly anything in it. I filled it all the way up, put it back on and let all air out of the pressure check valve. It started up on the second attempt and has run since.
Still unknown what actually caused it to happen. I took spare filter, gas and tools with me when cruising around to test it out. So far, so good.
robscarab
07-12-2007 04:59 PM
eWebtricity
05-22-2005 08:45 PM
Pure Energy
12
10-03-2002 09:38 PM
