bravo 1 drive gear cases ?
If you can find someone that can fix a damaged tower in the upper, I'll give you one, you just pay shipping. I don't know if it can be fixed or not. The gears went out and the tower in the upper case was damage. It is from a 1998 boat that was always in fresh water. 608-751-4981
Mark
Mark
I was allerted of your post by RECKLESS. I have stumbeled upon two new drives, in a box last year after I spent $910 each for gears alone, to rebuild both my drives during the winter and one died 30 - 40 hours later (usage hours) when the new gears were put back in a case that wasn't right from ware to begin wiith. Might have lasted longer had I not screwed with it but it was to go none the less, they were both orig. in my 91 Hawaii.
I will send you a PM
Super Hawaii 40
Super Hawaii 40
Charter Member #601
26Sonic..
"i'll use the gears from the original drive just want to transer them over to new shells."
Easier said than done.. all those parts have to be set up right or they wont last long.
US! Fountain..
that is pretty pricey.. on the labor. I guess I should be charging more??
Dick
US! Fountain..
Dick
Ginger or Mary Ann?
Originally Posted by Mr Gadgets
26Sonic..
US! Fountain..
Dick
US! Fountain..
Dick
That's what I thought too! So I did what every other toolmaker would do.......make all the setup tooling and do the reassembly myself. Suprising how easy it really is. I did both of mine. I even found the backlash was way off from the factory on 1 of my lowers. With me being the owner and not assembling the drive as just another 'job to be done', I can say I spent way more time making sure everything was perfect and exact than what I would possibly recieve from a dealership.
Charter Member #601
On the uppers, did you find the driven gears were not equal distant from the centerline of the pinion gear?? Or didnt you get into the uppers?? I spend as much time as it takes to make it right. Like you said, some dont..
