M.E.k. to remove decals ?
Hi, I want to remove some old decals from my boat. I believe that using MEK will not harm the gelcoat, but am not totally sure. Is it ok to use? thanks.
Originally Posted by BLOWNBOAT
I used the decal remover that they use in body shops that goes on a 90 or a drill. Just dont spin it to fast. Worked great.It is a round eraser.
1 Post
Heat gun is the trick. Lift one edge and peel back slowly at a 180 degree angle. You may get all or most of the adhesive up if you are careful and patient and save some elbow grease later. Using any type of solvent on your gel or paint could be very very bad for your finish.
Depending how long your decal has been on will also determine how much discoloration you will have from the rest of the gel or paint.
Good old soap and water with a good rough cloth also helps. The soap and water will temporarily kill the tack of the adhesive so it balls up and rolls off with elbow power. Not like wax on or wax off. Keep moving in the same direction. Not back and forth..
