Best setup for Oil Temp Gauge
I want to hook up an Oil Temp Gauge to my engine.....I prefer to mount it on the engine instead of in the dash....I am running the Mercruiser remote oil filter kit and would like to get a setup to mount the gauge directly to the remote oil filter bracket....Has anybody done this before or mounted one somewhere else on the engine? I prefer something simple and mechanical, something I can direct plumb.....Thoughts anyone?
Whats the most common way to do this?
Randy
"Bad-Habit"
Randy
"Bad-Habit"
Bad, that sounds like bad idea to me unless you move the helm to the engine compartment. I would think you would want to monitor the guage while underway. I say mount the gauge in the dash or someplace you can see it while operating the boat. Am I missing somthing?
I really don't have a place on my dash for the thing without totally re-arrganging things. Besides it wouldn't match my Formula gauges......I am not having a problem with the oil temp(that I know of). I usually check my engine out after a long run anyways and can in a matter of seconds have the hatch up to check the gauge. Mo you mention your senders are in the pan. Is a Oil temp guage similar to a Water temp gague? (If it is electrical). I just want something I can take a peep at everynow and then....Figured mounting it somewhere on the remote filter bracket would be the best. Hopefuly with some sort of a direct plubing setup...Getting to the pan is out! Untill I have to pull the motor. (which after 2 1/2 years of dialing in hopefully won't be for a LONG LONG time)
BH
BH
Toxic FORMULA
BH
BH
Plenty of people use the remote oil filter mount as a reference point also , it's just that the temp will be a little lower. It's also a hellava lot easier to install , once in the boat
BH
BH
See my previous post you can get a vdo guage that looks very similar to the factory formula but it will take some leg work.
http://www.offshoreonly.com/forums/s...ad.php?t=35137
If you just want to get a baseline go to Wal-Mart and get a digital thermometer. Go to the hardware and get a brass plug for the remote oil filter plug. Drill the plug to match the thermometer and JB weld it in. Remove existing fitting and screw the new rig in place. 13 bucks, hi and low memory with real time temp.
