New heads, manifolds, risers! lost power in 400 yards!
![Thumbs down](/forums/images/icons/icon13.gif)
454 magnum. New Merlin heads. New risers. New Manifolds. Put boat in and was running about 4000 rpms. Lost power. Sounded like a miss. Then heard loud rattling noise. Engine would not allow me to go above 500 rpms. And had intermittent "rattle or banging" on port side. Sounded terrible. Looked like there as a white-creamy stuff in top of valve covers. Someone please help.
Boat is a Velocity. Thanks.
Charter Member #655
Start with the easy stuff and work your way up....electrical first, Timing, wires and cap.
If your boat has a sail do you ride a horse to the ramp?
Charter Member #655
new cam too????if so did you break it in?????
Toxic FORMULA
![Frown](/forums/images/smilies/frown.gif)
I take it you pulled the valve cover ,so not a dropped valve or broken rocker, creamy white stuff is water or moisture, knocking is probably detonation.I would pull the spark plugs from the side that was banging and check those cylinders for water, even run water through the hoses in that manifold to see if the riser gasket is right. Did it smoke out the exhuast, on the side with the banging? if it did, probably head gasket not installed right or not the correct gasket, if the heads are aluminum they need special ones. Dyno's right start with egnition first.
