alpha drive trim
I took my drive off to replace the water pump about three months ago and now one of the trim cylinders is extended almost all the way out? the other is in? How do I correct this. Also, one of the lines to the drive unit from the pump has a worn out outer plastic sheething. I haven't seen any leaks so far but since I have the engine out I thought I would repalce the line. Can I get these made locally? any info would be greatly appreciated, thanks in advance.
Re: alpha drive trim
Rob, all you have to do is trim the rams all the way in. one will go in and bottom out and then the other one will move until it bottoms out.Or you can hook the drive up to the furthest cylinder trimmed out and push down and they will move. Any problems give a call or email me.
Pwrbt33- John S.
Offshore Performance
1-877-GOFAST1
410-827-0200
Pwrbt33- John S.
1-877-GOFAST1
410-827-0200
BadDog
9
09-09-2004 02:36 PM
