Help-454 MPI Engine won't crank, just clicks >
Old 06-01-2004, 07:49 PM
Default Re: Help-454 MPI Engine won't crank, just clicks
My money is on a connection. Solenoid won't cause everything else to stop working. I had the same problem, cleaned the terminals, cleaned the starter side, and it turned out to be the wing nuts on the top of termnals. Cleaned those up and tightned them, not a problem since.
Go Big is offline
Old 06-08-2004, 08:17 AM
Well, Roby, the hammer did the trick. Few taps while turning the key and started right up. Now it's just a matter of getting it changed out! Somehow I think it will be easier to type than to do.
NetGain is offline
Old 06-08-2004, 08:29 AM
robyw1's Avatar
Glad it worked out for you. That'l be $39.95
Roby
robyw1 is offline
articfriends
Wanted
1
09-16-2008 08:31 PM
rangerrick63
9
05-07-2007 09:05 PM
kraftaroni
4
07-19-2005 10:14 AM
YELLOW7
05-12-2005 02:55 PM
Elite Marine
4
01-07-2003 08:45 AM
Quick Reply: Help-454 MPI Engine won't crank, just clicks
