How much boost?
How much boost?
On my 29ft single Fountain I'm running a 509 w/Merlin heads, dual Nickerson 750's, roller rockers & lifters, superchiller intercooler, and MSD ignition. Using pump gas, how much boost can I safely run without getting into trouble
Re: How much boost?
Merlin Iron heads, Timing currently 34 degrees, Compression 8-1 I believe, B & M 250 Blower, Crane Cam (do not have the specs handy). The motor was built by Teague Custom Marine.
Re: How much boost?
I'm going to call them also. I just wanted to get some feedback from you guys first. As far as the timing goes, 34 degrees is where Teague wants it. I'm currently running 7 lbs of boost at full throttle. Just curious if I could bump it up a bit.
Re: How much boost?
Every thing sounds ok . I dont think i would turn it up much more.
Re: How much boost?
I am not sure but I do not think that blower is good for much more without building too much heat. After a point you get to diminishing returns. If teague has timming at 34 you might be able to add boost 7 backdown timing but I don't know if you will gain any HP.
