525SC blower capacity
The Merc manual I have doesn't indicate the capacity. It says to use 90 Wt. Gear lube and to fill both the front and rear cases. Dipstick for the front, fill until it runs out the rear fill plug. Sorry I couldn't be of more help. Good luck! Lou
I don't know the exact capacities. Don't really need to since it is nearly impossible to get all the lube out of them. I just suck out as much as I can and use the fill/sight hole for the rear and add slowly in the front and check the dipsick frequently while adding small amounts.
Originally Posted by thedykstras
The dipstick is kind of hard to read with the oil being so clear after a change. ![EEK!](/forums/images/smilies/eek.gif)
Yes it is. I usually just pull it out and and look for the lube in the indention on the dipstick. If I'm not sure, I lay it on a paper towel.
I just asked the follwing questions in a new post, but then found this one, maybe some of you are still receiving an email alert for this post:
so where is the drain, and fil level plugs for the rear, I could not see them
and do you check the front with the dip stick judt set in without threading?
and is merc hi performance gear lube the specified lube?
thanks
Ramb
thanks
Ramb
