Greasing the drive coupler >
Old 06-30-2004, 09:12 AM
Default Re: Greasing the drive coupler
500, in the next week or two i should be in oshkosh do'n some dirt-bike-ridin...u close to there? the owner of the team has a track in his yard...
audacity is offline
Old 06-30-2004, 09:24 AM
Official OSO boat whore
HP-I looked in the truck last night and saw that the mrs still had not returned the alignment tool to you! I'm going to put her on this asap.
Audacity-Hp will only be slightly out of your way. Maybe 30 minutes. On your way up to Oshkosh, there will be another dirt track on your lower left directly across from the Merc plant. Never ridden it, but it looks interesting.
Cord is offline
Old 06-30-2004, 09:36 AM
there is some big yam dealer around there that has a track that jeff built and maintains as well...
seems like everytime i'm in WI....IT RAINS!
audacity is offline
Old 06-30-2004, 11:01 AM
BAD-HABIT's Avatar
Originally Posted by US1 Fountain
I always grease until it just starts ozzing out.
Always easier to clean up a little extra than to pull a motor.
Where does it "ozze" out from?
BH
BAD-HABIT is offline
Old 06-30-2004, 11:08 AM
Member #9
hp500efi's Avatar
Cord, NP on the tool, whenever she has a chance.
Cord, Audacity, the Yamaha track you are speaking of is North of Oshkosh and is there if you buy from that dealer. We asked a few years ago if anyone could ride and he said at that time it was for purchasers only. Nice track and is catered for the smaller riders too.
The track across from Merc is the Fond-DuLac track. Privately owned and was once the owners practice track that he turned into a track for anyone. You need to be a member to ride that (simple form and money). Used to be real cheap to be a member until the insurance killed him so the rates went up. It was once $50.00 a year for a family now it is up to $275.00.
Joey, where is the guys track in Oshkosh? I am about an hour or so from Oshkosh..unfortunately my Summer is jammed but let me know, maybe I can swing something.
Member of the Liquid Jungle
hp500efi is offline
Old 06-30-2004, 11:28 AM
we can ride NP at the yam track...jeff is the one that keeps it up....he lives in winneconne and it's in his yard so we are not limited on times....i'll be sure and post if i come that way...
audacity is offline
Old 06-30-2004, 04:27 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
BH
From were the driveshaft enters the coupler.
Merc does make a grease specifically made for the coupler splines. 'course any grease is better than none.
US1 Fountain is offline
Old 07-01-2004, 06:11 AM
in a performance boat u should be checking the u-joints more often anyway.
i think there are two fittings
audacity is offline
Old 07-01-2004, 07:09 AM
97BossHammer's Avatar
where is the zirk for the coupler? do you grease it from the zirk on the drive itself.....or from inside the engine compartment? I must be over looking a zirk.
97BossHammer is offline
Old 07-01-2004, 09:21 AM
HiPerf2000's Avatar
There are 3 places that you should shoot with the gun.
1. Pull the drive and hit the zerks on both u-joints. 2 Zerks.
2. Re-install drive and hit the zerk on the outside lower right of the gimble housing to get the gimble bearing. 1 Zerk.
3. Looking stright down from the top at the back of the motor you will see where the shaft goes into the coupler. on the face of the coupler there are 2 Zerks 180 degrees from each other. You may need to tap the key to hit both of these.
5 Zerks total and only 1 Jerk needed to Grease them.
HiPerf2000 is offline
Quick Reply: Greasing the drive coupler
