BravoI impeller replacement >
Old 07-13-2004, 01:30 PM
Default Re: BravoI impeller replacement
I have a 1989 Formula 272SR-1 that I have had overheating problems with also.
Formula used a fresh water flush that has a valve installed between the transom assy. and the seawater pump. If you have this, remove the hose from the transom assy. and check to see if the valve is all the way OPEN!
Mine stuck 1/4 of the way closed because of sand in it. Like to drive me nuts. Ran fine below 2500 rpm's but would overheat above that.
Cleaned out the sand and gravel and works great now.
I know that you had NO water out the exhaust, but.....just giving you a "heads up" for future problems with temps on the Formula brand.
OPIE272 is offline
Old 07-13-2004, 02:50 PM
Forum Regulator
Sydwayz's Avatar
Received 1,255 Likes on 548 Posts
I would not use oil to lube your impellor. Oil breaks down rubber. Use common househould dish soap.
Also, quick tip for installing all veins correct the first time... wrap a zip-tie around your impellor before install, lean all veins the right way, and then sinch down the zip-tie and insert into the housing. Then cut the zip-tie with a pair of long dykes, (the tool, not lesbos).
I would advise aligning all your veins the right way from the get go. The plastic housings have some lea-way when you spin the impellor, to allow the veins to correct, if need be, but you are weakening the housing by doing so, even if for a second. The brass housings do not have any give. I have heard stories of veins flipping, and wedging the impellor solid in the housing. I always install my impellor, outside of the boat, entire pulley in hand, and look down he water intake tube to inspect each vein as I rotate by hand, to make sure its all good.
Sydwayz is offline
Old 07-13-2004, 03:03 PM
GLH
GLH's Avatar
Sydwayz has it dishwasher is the trick. He uses it instead of K-.... oupps getting off track again.
GLH is offline
Old 07-13-2004, 08:42 PM
Namwot's Avatar
Originally Posted by TMANN
I have had to do it twice last year and can now do it in 15 min in the water. I always carry a spare after the last time...
TMANN
If you take the inlet hose off of the pump with the boat in the water, does water start running in the boat? The pump has been a problem on my Bravo also. This season I actually stocked the boat with a spare pump and the few tools it takes to change it. I just am not sure if you would want to take the inlet hose off in deep water or if you need to beach the boat first.
Namwot is offline
Old 10-20-2006, 10:05 AM
Why not try the Globe Blue Run Dry blue impeller?
mwk4619 is offline
Old 10-20-2006, 10:14 AM
Member #154
Indy's Avatar
Do it after you read this, it's a pictorial from Wally...he did a great job...
http://www.speedwake.com/upload/show...0&pagenumber=1
Indy is offline
Bill272
05-18-2005 11:13 AM
Jeff Pierpont
1
03-28-2005 08:30 PM
gripit
5
12-19-2004 09:35 PM
Waterdogs
07-19-2004 12:16 PM
mjpcowboy
14
02-21-2004 10:44 PM
Quick Reply: BravoI impeller replacement
