Lower shift cable replacement
Hi and HELP !!!!
Can the lower shift cable on a Bravo drive be replaced on the PORT engine with both engines installed ? this is in a Fountain ?
I'v e done it on a starboard engine but things look much tighter on the Port engine.
ed
ed
Were doomed!
there should be no reason to pull the engine out to replace the shift cable. You will need to remove the outdrive to unscrew the cable nut though
-Wally
-Wally
Thanks Wally. I knew about pulling the drive from replacing the cable on the other ( starboard) engine. Looking at this ( port) engine access seemed tougher and figured I'd ask here.
ed
ed
DrFeelgood
Drives and Lower Units
5
11-05-2007 09:42 AM
