How much HP will this make???
![Question](/forums/images/icons/icon5.gif)
I am building a 454 vortec in place of my exploded 454 mag and don't have a HP program avail. Any of you guys willing to plug these in for me? Thanks
9.25 :1(I had the block decked)
vortec heads(stock)These are not peanut port but about 260cc and good exhaust flow and 1.72/2.09 valves
224/234 roller cam
511/544 lift
dart single plane with oval ports
800 holley DP
Rev marine exhaust(like Gil)
Total timing unknown but I heard these heads don't like or need more than 30,any suggestions?
224/234 roller cam
511/544 lift
800 holley DP
I hate the winter!!
Cooltoys,
I punched in your #'s, but I really need more information for your cam. I need the valve timing #'s off the card. If you have them, post them @ .050
As I entered the #'s :
r.p.m. h.p. torque
3500 263 395
4000 330 434
4500 402 469
5000 461 484
5500 503 480
6000 529 463
6500 537 434
I used a Dyno 2000 program.
r.p.m. h.p. torque
3500 263 395
4000 330 434
4500 402 469
5000 461 484
5500 503 480
6000 529 463
6500 537 434
Very different from mine, I'm showing 487-HP @ 5500-RPM with a steep drop off at 6000-RPM. Max Torque is 470 @ 4500 droping off at that point. However as with checkmate I need more detail.
it's Chevy part # 12366543. 224/234 @.050. 527/544 lift.110 ctrline. I don't know what I'm missing here. Thanks for your work. I'm looking for a good torque, 450hp so your #'s sound good to me,,, either set.
I hate the winter!!
The program I have will not allow me to enter duration and centerline #'s. It requires me to enter exact valve timing ( IE: intake valve opens @ xx* and closes at xx* as well as exhaust valve) Then it calculates duration, lobe seperation and overlap from those #'s.
