Bravo 1 Transom assy ?
Jerry B
Just spent allot a $ having a new transmom assembly installed because of bad water leak at the tiller arm seal . Was going to have it repaired but allot of salt water damage and some previous bad repairs.
Anyway my question is, are there any provisions to lube the upper and lower pivot pins/ steering pins. It was the upper that had worn and caused the water leak. Seems to me there should be a way to lube these pins.
Thanks for anyones help.
