MOBIL 1 OIL FILTER for 502 efi? >
Old 08-17-2004, 02:12 PM
Excalibur502mag
Question MOBIL 1 OIL FILTER for 502 efi?
After reading all the good information on the Mobil 1 20W-50 V-twin oil, I have decided to give it a try. It is time to change the oil in my 1999 502 mag, and I want to do it right.
Can someone tell me which oil filter is best? I read that some of you used the Mobile 1 oil filter with the good results. Does anyone know which filter I need? I have tried my local autoparts stores with no luck for info on the Mobile 1 filter. Is the filter that important?
Old 08-17-2004, 02:59 PM
Excalibur502mag
Default Re: MOBIL 1 OIL FILTER for 502 efi?
Thanks a ton Wildthing,
I did a search for a thread like that but didn't find anything. Strange!
I am curious about the late 90's 502 mags and the remote oil filter not having enough room. Do I need to worry about this on my 1999 model?
Old 08-17-2004, 03:03 PM
HiPerf2000's Avatar
If there is not enough room because the filter will hit the manifold, you can always reverse the mounting location of the filter on the "L" bracket from the bottom to the top. it gives you the extra 2+ inches that you need.
HiPerf2000 is offline
Old 08-17-2004, 03:47 PM
Hydrocruiser's Avatar
Arrow Re: MOBIL 1 OIL FILTER for 502 efi?
Oil Filter f/ most Mercruisers
FYI:The thread type on the filter is 13/16-16.
Fram: PH5, HP4, DG5, PH13 (no anti drainback) Pureolator: L34631
Purolator Pure One: PL34631
AC: PF1218, PF932
Motorcraft: FL-12A
NAPA: 1060, 1060gold
Wix: 51060
Wix Racing: 51060R, 51061R R= Racing
K&N: HP3002
Baldwin: B1428 (Top Rated)
Amsoil: SDF-24
Hastings: LF279
Fleetguard: LF3679
Mercruiser: 35-802885Q
Mobil 1: M1-302
Kendall: K31
Penzoil: PZ45
Quaker State: QS5
Shell: S63, SH38
Texaco: T38, T38B
Warner: PH1218
STP: S01218
Valvoline: V056
FYI http://minimopar.knizefamily.net/oilfilterstudy.html
A/C 454 (short) is equal to Mobil-1 M1-111 (shorter filter)
I was told that the Mercruiser 35-802885Q is for all V-8 engines but they make a "long" and a "short" version.
Now a longer filter is not a better filter according to Bob's. Heavier springs on a longer filter can even slow flow rates. Don't make assumptions. If you are going to extend drains you still must change the filter at the recommended oil change interval and additionally use a < 10 micron good flowing filter like a Mobil-1; Baldwin or Amsoil or equivalent.
The Mobil-1 is made by Champion Labs the same company that makes aircraft oil filters. Bob said they are not the same company that makes spark-plugs.
Hydrocruiser is offline
Old 08-17-2004, 04:18 PM
Excalibur502mag
Thanks for the info,
I bought the Mobil 1 M1-302. Does this have the anti drain back feature?
Should I have specified the 13/16-16 when ordering it?
Old 08-17-2004, 04:22 PM
http://shop.store.yahoo.com/rodi/mob1higefoil.html
That I don't know I would think it does. That is the same fliter the Humm-V uses interestingly enough.
Old 08-17-2004, 08:30 PM
WildThing's Avatar
That's why I use a fliter magnet too. The additional protection is worth it compared to the cost of the magnet. http://www.filtermag.com/
Hilsinger & Sp33dwake forums sell these magnets too.
Excalibur502mag, yes the M1-302 is an anti drain back filter
WildThing is offline
Old 08-17-2004, 08:34 PM
Yea, that filter can hold back metallic particles down to <2 microns and I imagine last forever. A definate good spend.
But can it hold back a "hairpiece" ??
Old 08-17-2004, 08:43 PM
http://www.champlabs.com/
They make the Mobil-1 and a few other fliters.
Old 08-17-2004, 08:51 PM
This sums it up pretty accurately. There are a few good choices out there.
Attached Thumbnails MOBIL 1 OIL FILTER for 502 efi?-oil-filter-efficiency.jpg
Quick Reply: MOBIL 1 OIL FILTER for 502 efi?
