Eagle Rotating Assembly
Re: Eagle Rotating Assembly
All cranks need to be checked before the engine is built. I have run Eagles in numerous motors with no problems, and these have been 6000+ RPM engines. Running top dollar parts shouldn't be a reason to not go over all tolerances and clearances with a fine tooth comb, and that is the responsibilty of the engine builder. I have heard of problems with Lunati, Callies, and other cranks, but likely those problems are build problems rather than crank problems. If you trust your engine builder as being competent then spend the extra money on heads or something that will give you a few more HP. Just my .02!
Craig
Craig
$2300 should be a price for a complete assy. including bearings and balancing. If that is just for the crank, rods, and pistons he is high as B4 more has mentioned.
Hey, ateco just posted an add for A 540 rotating assembly for somewhere aroun $1750. check them out. He is using scat crank and J/E SRP pistons. top of the line in my opinion. I think
he is in the deale or advertisors section
I am going to have two 540's (tall deck) built this fall by a local engine builder. He gave me a list of what he is going to use, everything sounds good except I am reading some negatives about the Eagle rotating Assembly (mainly the crank).
It is going to be a mild 540 about 580hp, will I be alright with the Eagle crank?
Bulletproof is Billet !!!! Scat or Crower !!
And its not about the HP or Tourqe it was because of 6 footers running at 75-80 !!
Would not use eagle anymore unless in a 300 HP fishboat.
