Trim pump and bypass pressure
A quick way to check cylinder leak is. Bottom the cylinder then remove
the other line at cylinder while some one is holding down the switch in the boat if it pisses out of the cylinder its leaking internally.
If the rod is scored internally and the movement goes by the score
this test will not work.
Another thought would be to set your tab height then remove both lines at pump and get a fitting to tie them together. Take the boat for a ride. this would rule out the rams completly.
Im with CMS racing Your running the wrong pump. You need to run the
black Kiekeffier style with the metal cans on the bottom.
Good Luck
Gerry
Good Luck
Gerry
Hey guys thanks for all the tips. WE burried my mom today so the boat has not seemed important.
I do have an old HP pump I can try Fred how much for a new pump with no brackets?
gripit
2
05-04-2006 07:50 PM
