oil pres. issue, advise needed
Originally Posted by 502procharger
here is what i have -10 out of the motor into a -10 to -8 reducer because that is what goes in and comes out of my remote filter. -8 to a 10 fitting back out of the filter, -10 line to my oil thermostat, -10 to my cooler, -10- out of my cooler back to my thermostat, then -10 back to the motor. i needed a oil thermostat because i would only get my oil to about 150 because my cooler is so large but i wanted a large cooler for when i run hard. with the eddie marine thermostat my oil bypasses the cooler until it reaches 215 the maintains that temp no matter how hard i run. the oil pressure never dropped like it does not and has gotten worse with time. i figure if the oil lines were being restricted by the 2 -8 reducers into and out of the remote filter it would have always been low and not progressivly gotten worse right? like i said the motor needs to come out anyways for the ring gear replacement so i will pull the pan, prob replace the pump anyways and check all the bearing clearance. what should the main and rod bearing clearances be? thanks.
I would think the oil filter adaptor would have 1/2 pipe thread ,if so run the # 12 hose . I did this on my boat and race cars.On the Chevelle the headers raped so close to the stock oil filter I ran the #12 lines and put the oil filter adaptor on the raditor suport and the oil pressure did not drop and it ran cooler because of the extra line and the filter away fron the block.
I allways use the Earls swivel seal fittings .They are more money but the ease on use and they dont neck down like on the 90's
ok, i took the motor out today and found a slight kink in the motor out to filter line way low near the motor it was not visible with the motor in the boat that might have been the issue. maybe as it got hot it kinked more????? i am re-placing it and re-routing that line. here is my question though. i figure if it was restricted it would have highr oil pressure. i though oil preassure was a result of oil only being able to excape the small bearing gaps and such, so a restricted line should increase back preassure right???
check out www.hotboatpics.com for all the stuff we can't post here!!!
![hot head](/forums/images/smilies/hothead.gif)
Originally Posted by Strip Poker 388
Hey Reed the pictures kinda looks like Bob teague ![EEK!](/forums/images/smilies/eek.gif)
powerqrudy
Drives and Lower Units
7
08-28-2008 01:33 PM
THRILLSEEKER
02-04-2004 10:05 AM
