desperately seeking Gen VI flywheel for cast crank 454/502
I found one here,now I blew my port Mtr and need another for a '97 cast crank 454. I'm pretty sure the casting # on the flywheel is 10101171 and the part # is 12556918. Thanks for your help.
Actually,most newer 454's have a flexplate, and I need a flywheel. Floridianson(a fine member of this board) sent me one for my last update for the cost of shipping,,,saving me $220 or 11 yrs membership for you. No, I haven't gotten around to signing up yet, to busy working on 2 blown motors and reading magazines. Don't know if any came on the 502 but it should be bal. for a cast 454,not forged.
I saw this posted th other day....
don't know it it is still available or not...or what year it is...
1 pair Goodyear Dyna Torque 30.5
x 32, uncut $500.
1 Chrysler Super Magg III, fresh, $300.
1 PSI Rev Limiter, $500.
1 454 Nod. Iron Flywheel, $200. <-----<<<<
1 Scatter Blanket, $150.
1 PG 150 Fuel Pump, $250.
1 Belt Drive for Ext. Fuel Pump BBC, $250.
1 Net set KB 454.030 pistons & rings .250 dome, $300.
All prices are Canadian
Call Ken at 519-846-9231
x 32, uncut $500.
I may still have one from last seasons repower. will check tomorrow and let you know. Also had to buy one last yr for one of the motors and wasn't too bad will let you know what I find out without goggles on...
![Smilie](/forums/images/smilies/smile.gif)
Originally Posted by Tempest
I'd charge him double... just because he sounds like a homo ![Smilie](/forums/images/smilies/smile.gif)
1 Post
I have two flywheels from '89 454 mags ... these were Mark IV blocks, so I don't know if they are compatible. PM or call me @ 419-882-1680 if you can use them.
Chris
Chris
Registered User
If you cant find anything you can always match the flywheels up on a balancer. Did one for a customer last month. kr
