MSD high vibration coil
Toxic FORMULA
Re: MSD high vibration coil
Originally Posted by sutphen30
its only a coil,of course it will work.
A coil is not a coil...some have internal resistors , some require an external resistor or resistive wire.
Originally Posted by PROFILE
Can the msd high vibration coil 8222 be safely used with a stock mercruiser thunderbolt IV ignition system?
The MSD tech book has a chart listing the 5,6 and 7 series MSD boxes and which coils can be used with each.
The HV coil is recommended for each box.
Thanks for the input.
I figured it would be ok,but the msd instructions made me a little cautious by stating you must use a resistor on stock ignitions. Figure they must be refering to points systems. Better safe than sorry ,thats why I asked.
