Gaffrig starter lockout switch where...
The little switch on my shifter is wasted where do I get one?
It has 3 little male tabs on the bottum and 2 screws on the side holding it to the assembly.
Lee.
Lee.
You can order them from most electronics shops for about $2 each, or you can order one from Gaffrig for about $30, if my memory is correct. I had one break about 2 years ago. If you buy any, I suggest that you buy more than one. When you re-install the switch, be sure to get the little plunger positioned correctly in the "sandwich" when you reassemble the shifter/throttle. I was not paying attention and did not push the plunger in, under the ledge that it rides on, and it broke the side out of my brand new switch. Since they were so cheap, I bought a couple of them. I donated the rest of them to my friend who runs a marina and occasionally needs one or two. You can get the part name and number directly off of the switch, or if your's doesn't have it, I can look it up when I get home from work.
SHAKEN Not Stirred
29
06-26-2003 01:05 PM
