525sc cam specs
Re: 525sc cam specs
Actually I've found several spec mistakes in Merc manuals. I use the specs in the "how to build a high performance big block" book.
[img][/img]
[img][/img]
MarineKinetics
Re: 525sc cam specs
That is a mis-print in the Merc manual. (I have the same one) The cam from the factory is a Crane 132561/H-228/312-2S-14 T1.2. Specs are on the above cam card.
Bob
Bob
Re: 525sc cam specs
Would this cam work with my exhaust under water? If not can I get a cam with a special grind that will work just as good as this one?
Mark
Mark
