Went 96.2 and blew the outdrive
Re: Went 96.2 and blew the outdrive
yeah ive been thinking the same thing.spoke to a few people who had them on kryptonites with around the same hp and they lost some speed with the 136 and smaller prop.and i have a collection of big props 31 hydro 34bravo and 33 hydro for the 1.50 ratio.if i had the hp to turn the 31 hydro with the 1.36 outdrive i would go that route.502procharger i need to speak to you my cell is 203 434 6142 or email me.sean
I'm going with a xz drive on the boat(thanks again brian).i know i need to change out the gimble bearing and put trim limmiters in but was looking at a old post about upgrading to the xz and it was mentioned that there are a few other changes that must be done that i havnt heard about a different bellows ring and a grease seal must also be changed? and somthing that holds the gimble bearing in? also anyone know where i can get the spanner wrench to take the trim cylinders apart the local dealer wants like $150 for the spanner wrench.i had 1 package of trim limit spacers #15768a3 i never used is that all thats needed 1 spacer per side? thanks everbody for all the help.the boat wouldnt have got this far this fast if it wasnt for this forum.
t500hps
09-16-2007 08:56 PM
