Plumbing a mech fuel presure gage? >
Old 09-09-2004, 05:44 PM
Default Re: Plumbing a mech fuel presure gage?
I put in an electric Gaffrig gage to monitor my tweaked 575sci and I've been satisfied that's it's accurate enough to alert me to a problem. I have mine plumbed to a boost referenced fuel regulator. We did originally set the fuel pressure however with a mechanical gage at the regulator and if there is ever a question you can temporarily throw a mechanical on at the regulator to double check that your electric is working properly.
zahndok is offline
Old 09-15-2004, 08:35 PM
Elite Marine's Avatar
I agree with the potential for a leak, but a braided line such as an Aeroquip would probably outlast several motors before failure.
A mechanical gauge on a blower motor is the only insurance that you have true fuel pressure. Go lean and plan on dropping a few $$$.
Don't use the plastic hose unless its nylon. Parker makes a line called Paraflex in several different materials. Nylon is rated for fuel.
CIG 3 seems to have the best recommendation. Whats the part number, I can't locate on the Summmit site?
Elite Marine is offline
Old 09-15-2004, 08:46 PM
Here's info on the Autometer Isolator. I'm definately going this route!
http://hp.autometer.com/techtips/faq...s_on_dash.html
Old 09-15-2004, 08:51 PM
Here's the link to the part at Summit
http://store.summitracing.com/defaul...ch%2Easp&N=100
Old 09-15-2004, 09:00 PM
jimjomack's Avatar
Aeroquip makes a PTFE hose size -3 with reusable fittings you can install at each end. This hose is rated to 3000psi burst. I have used it for my mech oil pressure lines. Just cut it to the size you need. 40 feet of it cost me about $300 with fittings
jimjomack is offline
Old 09-15-2004, 11:35 PM
robyw1's Avatar
Use an isolator with premade steel braded line if you must use a mechanical gauge. I would never use that nylon line because if that line should ever get a hole rubbed in it then you have a dangerous situation. In the event of an accident and the line was severed you would have a flame thrower under your dash.
Never use that nylon line in any application involving flamable liquid. If you read the instructions it will warn you not to do so..
Roby
robyw1 is offline
575cat
3
03-09-2008 09:06 PM
baja383
4
10-04-2006 08:35 AM
Sea-Dated
Fountain
3
05-02-2006 11:56 AM
Strip Poker 388
4
02-24-2004 11:06 PM
Strip Poker 388
3
02-24-2004 09:30 PM
Quick Reply: Plumbing a mech fuel presure gage?
