Can Not Figure It Out,,Please Help
#31
Re: Can Not Figure It Out,,Please Help
Are you certain the drives are trimming evenly? One higher than the other will have this affect. Also, you may want to take measurements on the toe in/ toe out setting of the two drives.
BT
BT
#36
Beak botr
Originally Posted by tm29
also not sure about the toe in toe out thing at all. not sure how to check or set it
#37
With the drives straight ahead, use a tape measure to get the measurement between the drives at the front of the bullet. Then measure center to center between the ends of the prop shalf centers. For spinning out I would have the prop shaft centers further apart than the front of the bullet by about 1/8". This is at least a good starting point. You adjust the tie bar.
BT
BT
#39
How tight are the drive hinge pins and gimble pin? Any noticable slop up/down left or right? Are there any sea water pickups, transducers, trim tabs or anything else that may be causing turbulation on that side?
