couple of questions
1. When out of the water on a garden hose one drive slightly vibrates, but doesnt do it in the water is that normal or a sign of something starting to go wrong. It is a bravo drive.
2. on a 7.4 mpi I assume the connection to check the fuel pressure is on the fuel rail. does this mean you have to take off the upper manifold or is it easy to access. where is it maybe.
3. on setting the timing where is the disconnect so the computor wont adjust timing.
thanks for any help at all
the reasons why I am asking these questions is im getting a slight surge on 1 engine and want to start there and see how it goes done compression test already on both engines and is all good. done a complete tune up as well plugs etc etc and still a slight surge. surge is constant at all rpms not just at WOT.
I had the plastic top piece off of My 7.4 MPI recently. The fuel pressure port was right there in plain sight. Up front if I remember correctly. Even though it was painted black along with everything else.
Mine has a plastic top piece that says 7.4 MPI on it. a couple of torx head screws and the oil fill cap holds it on.
If I rmemeber the fuel pressure fitting came out from under the cast manifold in the front. Looks like a big truck valve stem.
