Drive break-in?
Drive break-in?
Is there any method to break-in a new bravo drive? How many hours to the first oil change? What oil is recomended? thanks, chris
Charter Member #601
Re: Drive break-in?
the manual says to run it easy for 10 hrs. If it has XR gears, I recommend an oil change at the first 5 or 10hrs. The XR gears give off a bit of metal. Nice to get it out of there.
I also like to see people run at medium speeds, vary the speed and get the drive warm and then slow down and dunk it in the water.. Hot and cold cycles, let everything settle in.. then you work your way up to WOT.. I mean, would you like to be woke up in the morning and no chance to warm up??
Just my .02!
Dick
Just my .02!
Dick
