ended up limping home DOH!! what the f-? >
Old 10-05-2004, 04:24 PM
Jonas's Avatar
Default ended up limping home DOH!! what the f-?
ok runnin along all of a sudden port motor drops about 1500 rpm, i slow down alittle check all gauges again all looks sounds fine,
i give it some throttle and the port motor lags behind and then all of a sudden bam its back to normal, hmmmm
i am getting concerned.
i turn around heading back it starts gurgling and has huge loss of power.
so i cant keep it on plane and we start to idle home.
after about half an hour or so started the motor and seemed fine??
ran for abut 15 min and got wierd again..???
then flip flopped and was fine again,, what the ??????
any ideas msp spark addon boxes?
its a 35 fountain 02 with 575's with whippleinner coolers, msd add on. etc. 200 hrs on motors.
Jonas is offline
Old 10-05-2004, 04:34 PM
fund razor's Avatar
Default Re: ended up limping home DOH!! what the f-?
I don't know man....
I'm just here for the "DOH!"
fund razor is offline
Old 10-05-2004, 04:45 PM
Geronimo36
Panther's Avatar
Check the coil and dist. cap rotor etc. I've seen the coil go bad and make that happen, it can drive you crazy. Swap coils and see what happens.
It can also be fuel. Is the motor popping and farting out of the intake? If it is than you are having a lean condition.
Panther is offline
Old 10-05-2004, 04:48 PM
Jonas's Avatar
hmm interesting that could be it..... i think u hit on the head... lean too long, oh oh could be too bad..
Jonas is offline
Old 10-05-2004, 04:52 PM
SORE MEMBER
Wobble's Avatar
water in fuel?
Wobble is offline
Old 10-05-2004, 07:10 PM
Toxic FORMULA
mopower's Avatar
Number one thing I would do is swap MSD boxes. I have my own opinon of these and it's not good
mopower is offline
Old 10-05-2004, 07:34 PM
InXS's Avatar
I had a '93 35 Fountain w/525 SCs. Mine reacted the same way one day. Turned out it was the MSD. Swapped boxes (MSD's) like Mopower is saying and found the problem quickly. Ordered the part I needed and was back on the water the next weekend.
InXS is offline
Old 10-05-2004, 08:42 PM
Mentalpause's Avatar
I had a similar problem on the port engine, it was dropping about 1000 rpm. The engine sounded fine, it just seemed to be fuel starved. Turned out I had a soft spot in the port fuel hose and it was intermittantly collapsing the inner wall. Replaced it and never had the problem again.
Mentalpause is offline
Old 10-06-2004, 08:10 PM
Dont the Fountains run individual fuel tanks to each motor ?? Id bet on the water/fuel seperater being full. Check the easy obvious stuff first.
otis311 is offline
Old 10-06-2004, 09:31 PM
Don't forget the anti-syphon valve at the tank. Most fuel problems can be traced to these valves. Most of the time you can just clean out the debris from the spring but I have seen small pieces of plastic that float get in the pickup and cause an intermittent condition. But I'm with InXS on this one sounds like the spark box.
offshoreratboy is offline
Quick Reply: ended up limping home DOH!! what the f-?
