Urgent! Engine stand ??
#32
I had the same problem. ****can that stand, and spend some money for a good OTC brand stand. I got mine, and dropped a full dress HP500 with exhaust on it, and it didn't even budge. Plus, it has a cool geared crank to rotate the motor. You won't regret the money spent. Plus it rolls around the garage with no effort.
#33
strip poker, You mentioned that you wnted to add bearings on the head to make it easier to rotate the engine. DONT DO IT!!! I thought that was a great idea myself a few years back and fabricated a stand with a roller bearing head. as soon as you loosen the lockdown the motor just spins to the heavier side and when you have pulled on head but not yet drained the oil this makes a large mess. I now have one with a gear crank like the OTC that is the way to go.
#34
Be careful with the name brand American made stands,hoists,jacks,ect.such as OTC Blackhawck Lincoln as many of these manufactures are selling imports to compete.Most people won't buy a 1000 buck floor jack that is designed to be used daily and rebuilt when wore out when they can buy 10 cheapies for the same price.Once I have the engine assembled to short block point and don't need to flip her upside down anymore I instal the engine mounts and wedge some 2 x 4's that are cut to the right length under them for added security when she's sitting unatended.
#35
[QUOTE=MILD THUNDER]I had one of those made in china cherry pickers. It was rated at 1000, 2000, and 3000 lbs depending on how far you pulled the boom out. It would want to tip forward at the 3000lb setting when pulling my 400 pontiac motor out of my car. Had to have my buddy stand on the back of the hoist for ballast while I jacked motor out. They are crap. Doesnt the government check the safety on these things? I should have let the engine fall on my buddy and we could have sued the manufacturer. I always have my camera available.
[/QUOTE
The hoist from Harbor Freight I was referring to is rated for 4000# and weighs 225#. It's a well built unit. We pulled/installed several engine/transaxle/transfer case assemblies with it and were impressed with how well you could regulate the unit with the big knob on the release valve. We did NOT use it with the boom fully extended. I'm sure there's some real junk out there from China and the USA. Just one persons opinion that this isn't one of them
![Drink](/forums/images/smilies/drink.gif)
#36
Originally Posted by JCPERF
Strip poker,Do i see a 69 chevelle for those 29 by 10's on the garage floor.
Its a 70,Firestone 28 1/2 X10 1/2 . Its my little street car
#38
#39
I bought a good "china" 4 wheel 1250# stand on EBAY for $99 incl shipping(the guy sells many). I have a couple of old 750#"china" stands that have had dressed BBCs that didn't sag like that photo(although they were strained),sumpin ain't bolted on right.
#40
how fast?
