cam help: 502 with AFR 305cc heads >
Old 03-01-2005, 11:31 AM
  #141
KAAMA's Avatar
Default Re: cam help: 502 with AFR 305cc heads
WAGS,
Just wanted to clarify----are you saying that your engine(s) were dyno tested with GIL exhaust manifolds/tailpipes??? Thanks
KAAMA is offline
Old 03-01-2005, 11:40 AM
  #142
Crazyhorse's Avatar
KAAMA, you got one of your noisemakers on the dyno yet? I been flying under the radar lately and haven't been around.
Crazyhorse is offline
Old 03-01-2005, 06:14 PM
  #143
WAGS382's Avatar
Kamma,
yes we did run the Gil exhaust on the dyno, I have a set of dry "dyno" pipes to avoid the mess from all the water flying around. I had all the accesories running, sea pump, circulating pump, and alternator. I tried to duplicate the way it would be in the boat. I felt running headers would be a waste of time just to get a false and inflated number. Good luck with your project. Jeff
WAGS382 is offline
Old 03-01-2005, 07:56 PM
  #144
Queenie's Avatar
Jeff, congrats on completing the project. I guess you've paved the way once again
And just when we were getting close..............
Can't wait to see it perform this summer.
Hope you can come over and check out the progress on the boat this weekend....we'll be living there for a while.
Queenie is offline
cloudmaster_321
Do It Yourself, Boating on a Budget
13
09-08-2008 01:15 AM
crowntow
11
08-24-2008 08:50 PM
Fenderjack
26
04-11-2007 09:44 AM
PatriYacht
23
03-19-2004 06:31 AM
gene
13
10-12-2002 12:20 PM
Quick Reply: cam help: 502 with AFR 305cc heads
