Lifter ?
Charter Member #655
will the roller lifters from a Mark 4 block work in a Gen 5????
If your boat has a sail do you ride a horse to the ramp?
Dyno
They can be used but the require machining the top of the lifter bores down to clear the tie bars it's time consuming but it can be done. Good luck Laz Mesa
I just went back to Cranes website and checked. They give the same lifter part no. for 1965- 1995. There is a note however to check for clearence under the link bar on aftermarket blocks such as Dart, Merlin.
Charter Member #655
Thanks Ian! Hows the foot?got the Black Thunder put away yet?
MarineKinetics
Dyno,
The Morel lifters have a longer body and deeper set pushrod cup. They will work in Mk IV, Gen V & VI blocks with standard retro pushrod length.
Bob
Bob
Charter Member #655
Thanks for the info Bob! Ian I think we will skip the pirates ball....
