Edelbrock. Marine carbs / Road carbs (#1410 Vs #4111)
![Question](/forums/images/icons/icon5.gif)
OK, I know I can't use the road carb in a bilge. But the number of Quality Edelbrock second hand road carbs available in comparison to the marine versions is UPSETTING ME!.
I'm used to rebuilding my own carbs, in fact , I like doing it.
My friend manages a very profficient machine shop stocked in stainlless etc. So we can do the mods, but we dont know without buying one of each what needs to be done to make a 1411 a 1410 750 cfm.
Does anyone know the specifics of just what is the difference please?
Thanks in advance.
Steve
Thanks in advance.
Steve
From Edelbrock:
For use in marine applications, these Edelbrock carbs comply with U.S. Coast Guard safety standards. Cast surfaces are iridited with Teflon-coated shafts and pump arm for maximum protection. Other features include modified bowl venting, specially designed throttle shafts, accelerator pump seal, 3/8" inverted flare fuel inlet fitting, tube in airhorn for fuel pump vent, 5-1/8" flame arrestor flange, universal throttle lever and revised secondaries for improved transient performance. Note: These carbs have no vacuum ports and are not for auto use. Use our Carb Stud Kits #8008 or #8024 if needed, see page 41.Marine Carburetors For use in marine applications, these Edelbrock carbs comply with U.S. Coast Guard safety standards. Cast surfaces are iridited with Teflon-coated shafts and pump arm for maximum protection. Other features include modified bowl venting, specially designed throttle shafts, accelerator pump seal, 3/8" inverted flare fuel inlet fitting, tube in airhorn for fuel pump vent, 5-1/8" flame arrestor flange, universal throttle lever and revised secondaries for improved transient performance. Note: These carbs have no vacuum ports and are not for auto use.
However, even if you made all these changes, it would still not be CG approved. In the unlikely event there is a fire, consider the liability issues. Buying a "marine" carb is very cheap insurance.
Gary
Gary
Hi Chris, Gary
Firstly thank you for thinking, looking out for the safety of me and the fam.
FWIW a $500 carb actually costs the equivalent of $891 by the time its in my hands.
I need two, for a year and then if I can get a pair of 54201 inlets iridited I will need four 600's. Isnt it a pity that edelbrock pulled the plug on marine inlets.
Despite the fact that we know there is no upper limit on the price of safety sometimes you have to consider other options, because you have to accept, well I do! that you simply cant afford the very best of everything, all of the time. So why not use your own skills and (mates) resources to save money. If you can, and you can do it safely. In this instance if it is not feasible in engineering terms, then its out.
In the UK, if a device met a specification upon inspection, it would be given merit for that. Mother EU will put pay to that in no time I'm sure.
Steve
Steve
Ahhh, didn't realize you were in the UK. FWIW, edelbrocks (marine) are actually one of the cheaper carbs around here (under $250 new). If you're looking for a replacement, the edelbrocks are actually the old Carter AFB carb. You could check around for used marine Carter carbs (btw, these last forever since the shaft holes dont wear out like they do on automotive carbs).
Otherwise, if you must convert an auto carb, the main things are 1) vented to pour gas down the throat rather than spill outside the carb. 2) a hardline from the pump to the carb.
Gary
Gary
Gary
You are right to me they are by far the best value for money, no one else offers the features at this price level.
Thank you all for your advice and interest.
Gary it NOT going to happen...
Resale vaule
Modified car carbs value ZERO.
Interested marine buyers ZERO.
Interesed car buyers ZERO
Liability if I did mange to sell them either bunch OUCH!
Resale vaule
Charter Member #232
To bad you are in the UK as I have two brand new in the box that I am selling..
Jon
Jon
Put your best foot forward!
Jon
Jon
Every single thing I have bought for my boat has been shipped over from the US.
But what exactly is it you are wanting to sell?
Steve
in the event of a fire, the insurance company would find the non marine item and your screwed.
Chris G.
Chris G.
