AFR or Canfield Heads >
Old 11-05-2004, 12:28 PM
JimV's Avatar
Default Re: AFR or Canfield Heads
Originally Posted by john.sblendorio
Thanks for the input Jim. I believe the rev limiter is 5,250 so that will have to be increased for sure. How about max compression ratio on pump gas?
To be safe 10:1 with aluminum heads with no less than 92 octane.
JimV is offline
Old 11-07-2004, 09:58 PM
KAAMA's Avatar
Gas should be the cheapest part of boating---especially when you just laid down some heavy duty SMACK for a new pair of engines and don't want to chance detonating them. I try to give myself a little cusion by using a little higher octane that what I really need.
KAAMA is offline
Old 11-07-2004, 10:21 PM
JCPERF's Avatar
Aluminum heads:92 octane-9.6to1 87octane-9to1
Steel heads: 92 octane-9.4to1 87octane-8.8to1
This is a good conservative guideline for no detonation even if you get a batch of questionable gas.
JCPERF is offline
Fenderjack
26
04-11-2007 09:44 AM
Dean Ferry
3
07-12-2004 02:37 PM
PatriYacht
23
03-19-2004 06:31 AM
JimV
9
04-05-2002 08:40 AM
cigarette39
03-07-2002 11:51 PM
Quick Reply: AFR or Canfield Heads
