Cover Plate for Transom assy
Does anyone know where to get some sort of cover or block off plate for Bravo transom assy? Drives will be off over winter and I want to keep birds and the like from nesting in there. If I had a band or jig saw I could make some.
Re: Cover Plate for Transom assy
I bought a plastic one for my other boat from BoatUS. For my current one, I use a rect. piece of plywood that I drilled for the housing studs. No band/jig saw needed. You can also buy pieces of plywood already cut into small sizes at HomeDepot and Lowes so all you need is a drill and bit.
