525sc's Rebuild
#41
Yep - thanks mcollinstn a good brain workout is always healthy.
The B&M blowers were limited to 12k. Not sure about the Weiand. That was just an FYI. I had a ton of the B&M's over the years.
#42
Originally Posted by iamfaster
Ls, did you have the blowers rebuilt? if so, by who.
thanks for the info
thanks for the info
One was a little noiser than the other--came back the same way--but no problems so far.
L.S.
#44
ok..here we go:
- dart / merlin perf. head/ valve assembly aprox 310cc
-mild additional porting
-8:1 comp ( bumped up over stock 7.5:1)
-454 @ 30over
-1050dom from 525sc
-stock intakes from 525sc
-original Gill exhaust
-rebuilt wiand 177's (stock 3'' pulleys)
-full hydrolic
-want to avoid water ingestion
-high reliability
-smooth idol
-5,200- max r's @ peak HP
-cruise 3,000-3,500
Which cam over the stock Crane #132561? Would the 731 be considered the next size up in terms of performance? Dont want more than i need. Only looking to add 75-100hp with heads and cam.
i promise to end this thread soon
-454 @ 30over
-1050dom from 525sc
-full hydrolic
-high reliability
-smooth idol
-cruise 3,000-3,500
#45
We gonna have to charge you soon.Everything sounds fine, should work out well but make sure you dyno both engines and their fully dressed.
#46
hydraulic roller conversion will cost a little $$. Figure $275 for the stick, $400 for the lifters, and $80 for the pushrods.
A good custom blower grind in a flat hydraulic will cost less, you'll use the same pushrods, and a box of $75 lifters. You'll have to go "one size bigger" on the duration to get to the same power level as the roller which will soften your bottom end a touch.
Just a thought (since you are on a budget).
#47
Originally Posted by Crazyhorse
The Holley rebuild center isn't in CA, it's in Tenn. They charged me $550 to do one of mine last winter.
Could have sworn it was Calf------ An I think it was a little less than $500
#48
mc, think im gonna go for the full hydrolic, just dont know how different the crane 731 is from my existing stock cam. late yr 96' gen V 525sc.
#50
MarineKinetics
Faster,
132561
HYD-flat
298*/306*@.005
228*/236*@.050
.530"/.551"
109 ICL
114 LSA
168731
HYD-roller
288*/298*@.004
226*/236*@.050
.587"/.610"
112 LSA
107 ICL
Bob
132561
HYD-flat
298*/306*@.005
228*/236*@.050
.530"/.551"
109 ICL
114 LSA
168731
HYD-roller
288*/298*@.004
226*/236*@.050
.587"/.610"
112 LSA
107 ICL
Bob
