Hustler 500efi engine tear down & Build Up >
Old 03-21-2005, 12:58 AM
  #221
Rob
Strip Poker 388's Avatar
Default Re: Hustler 500efi engine tear down & Build Up
Rod side clearance came up to .025-.029.
Attached Thumbnails Hustler 500efi engine tear down & Build Up-engine-block-003.jpg   Hustler 500efi engine tear down & Build Up-engine-2-.060-over-070.jpg   Hustler 500efi engine tear down & Build Up-engine-2-.060-over-063.jpg
Strip Poker 388 is offline
Old 04-13-2005, 08:16 PM
  #222
mikes280's Avatar
hay how is this thing going also did you use the pump with the press in pickup and was it like the one melling has with the shafts through the cap i have been told that it does not excest if you did let me know of the part # thanks
mikes280 is offline
Old 04-14-2005, 12:55 AM
  #223
Rob
Originally Posted by mikes280
hay how is this thing going also did you use the pump with the press in pickup and was it like the one melling has with the shafts through the cap i have been told that it does not excess if you did let me know of the part # thanks
Whats up Mike ? I used the 10778 with the Moroso slip[weld]on pick up for a 7 inch deep pan. The pick up to oil pan clearance was good.the pictures are on page 4 of this tread..Once I get it in the boat i will know what the pressures will be .the Dyno's gage was not accurate..
I have been real busy finishing this project and I have been taking a lot of pictures and I will post the rest of the build up soon.I was surprised at the #'s Now I am Wishing I had speedmasters and it Looks like I will need bigger props than I already bought.
I am trying to be running in 2 weeks .Just waiting on parts .I will post the rest of the info after I get it running.
Rob
Old 04-14-2005, 06:18 AM
  #224
a little teaser for now joe candy cane
open87 is offline
Old 04-14-2005, 10:14 AM
  #225
Back4More's Avatar
Back4More is offline
Old 05-18-2005, 01:24 AM
  #226
Rob
Well the up and running now .No problems at all. I am just now getting caught up I will try to finish out my thread and post all the stuff what I did and went thru on putting them together.
My picks are going to jump around some , Not in order of assembly .
Attached Thumbnails Hustler 500efi engine tear down & Build Up-engine-2-.060-over-002.jpg   Hustler 500efi engine tear down & Build Up-engine-2-.060-over-060.jpg   Hustler 500efi engine tear down & Build Up-scratch-oil-002.jpg
Old 05-18-2005, 01:39 AM
  #227
Rob
I got to putting the second motor together and saw a scratch in the cylinder wall .When I tore the motors down I marked everything so everything could go back in the same hole .The scratch wasn't to bad and nothing I could do now . So I looked at that piston for that hole and what scratched the wall is stilln the piston
The machine shop was suppose to clean the piston. I double ck ed
Attached Thumbnails Hustler 500efi engine tear down & Build Up-scratch-oil-005-small-.jpg   Hustler 500efi engine tear down & Build Up-scratch-oil-007-small-.jpg   Hustler 500efi engine tear down & Build Up-scratch-oil-008-small-.jpg
Old 05-18-2005, 11:15 PM
  #228
Can you post your dyno sheets? Just curious what they did.
NOBODY is offline
Old 05-18-2005, 11:53 PM
  #229
Rob
I am going to
Old 05-18-2005, 11:57 PM
  #230
I am going to
Were you at the Tickfaw 200?
NOBODY is offline
Quick Reply: Hustler 500efi engine tear down & Build Up
