Hustler 500efi engine tear down & Build Up
#244
Rob
3.....................
#245
Rob
Here The heads are together bolted up.With using the Metal layer Fel Pro head gaskets I tried to make the head and block surface as clean and lint free as I could .The head gaskets have that soft rubber feeling stuff on them that attract any kind of stuff, It even shows finger prints in it .
Here I ck the rocker arm geometry with the new crane lifters,cam, and machining I figured it would be off. It was dead on in the center . ya can see the contact patch.
#246
Rob
I bought all new Crane Rockers also. Ck this out,Crane changed up the rocker from the stock 2001 500EFI to 2005. Looks a little different . They allready have the corners radiused
Cool
Note!! In the box on the new Crane rockers it said ck the treads on the polly lock for burs.It said if there is a tight spot in the ajusting nut to run a tap thru the thread in them . There was a lot of them that needed retapping
![Frown](/forums/images/smilies/frown.gif)
#247
Rob
The tappets are alittle different also. The oil hole on the side and the plunger. Both are Cranes
#248
Rob
#249
Rob
