Hustler 500efi engine tear down & Build Up
#321
Rob
oring held at 7lbs,at 8ish it needs some sealer.it holds now, sure would be nice if we could put some bolts in that blank area,
Distributor corrosion sux,
dull valve covers,there the worst and first to go,they stay polished about half the season,then ya pull em,salt water spots ,ya have to get the water off as soon as its splashed
#324
Rob
innercooler orings,viton,I had a hard tome finding em
exhoust gaskets ok,draing pump,dull blower.
#326
Rob
cramped garage,still has residue from plasitgage,opps.rear main good
#327
Rob
norm top of rod,plastigage
last 2 picks shows the diff in the H and the HN rods,I dont like them being narrower.but its a stock crank,H might be better but im beating it somethimes
#328
Rob
Steering disassembled replacing all bushing,and plastic bushions,flat washers/spacersmake it like new and tight.also reploish
I hate the tensioner,its a SOB to polish
I ground down the factory bracket,it pinches the water inlet hose at this point,it help a little
the 4 Allen heads are the top pulley blower bolts,metric,with them snug you can feel slack in the bolt holes,I don't feel good about them,needs some arp with a wide head flange.Maybe even a dowel pin to locate it better,look at the bolts on a roots style blower,Maybe its not much stress on the?
#329
Rob
New arp crank bolt,also change the allen head intake bolts,narrow head,got arp 12pt,wide head,loctite.
Hustler hull side thicknes,orange,and bottom
#330
Rob
cockpit inner side interior panel,cut out for speaker,went thru some bladesyellow fiber
Whipple bypass valve, look at your diaphragm Ive been thru 3,they bust easy,
I cleaned up the wiring,nothing else to cut out of it
alt wire
alt wire
