Hustler 500efi engine tear down & Build Up
#351
Rob
Thanks Linnie,and are your blower on it yet? I'll send ya some of my extra energy,get after it bro
Rob
#352
Off the Radar
1 Post
Not yet, waiting on seeing Dave's hatch modification. I will need to do the same. Will happen this fall now, unless it keeps raining. Might start in August after all the trips are done. Keep up the good work.
#353
Rob
[YOUTUBE]http://www.youtube.com/watch?v=W9KsgFjI7ak[/YOUTUBE]
#355
Hey Linnie, Just stick those new blowers on there and make that hatch fit
(my hatch is out being modified; I'll shoot you some pics when I pick it up)
Randy,
Rob's spot on with RM Builder; He will spec grind any cam you want for your application. Again, hopefully you have someone to handle the ECU issue with any changes in cam and heads.
The blower has a way of over riding marginal heads Go have fun!
Also, as far as cryo treating, your guys will be the second in Utah
Dave
Randy,
Dave
#356
The time has come!
Thanks Rob & everyone else on this post. This site is the best place for advise & experience for us powerboaters. My boat is finally ready to lake test this weekend. Just in time for good weather & rising gas prices. Wide Open Performance came through. Once all the parts arrived, it went very quick & they did an awsome job. Break in this weekend & hammer down for the 4th @ Starvation! If I get close to Robs #'s, should be 85+mph @ my altitude.
#357
Rob
Up date us Randy????
#358
Been burnin up the lakes for a couple months now. 85 gps @ Powell. Minor issue w/ TPS connection. All is good, but now it's about time to put it in storage. Gotta move somewhere warm. Planning desert storm in the spring to see what she'll run at low elev.
#359
Rob
Ive had a few people interested in the valve cover fitting.They make it in #12 and 16,The fitting on the inside has holes drilled in it.kinda like a baffle.They list it for vacuum pumps.It makes a nice fitting run the #12 hose to the puke tank.Theres no leaking on the valve cover,no oil residue anywhere.The hole diameter is the same as the grommets and PVC valve hole,that works out good.
The part # is 22635 Moroso.
http://www.moroso.com/catalog/catego...?catcode=13635
<a href="http://videos.streetfire.net/video/Hustler-dyno-pull-911hp_70275.htm"><img src="http://px5.sfstatic.com/thumbs/0000/20/57/70275.jpg"/><br>Hustler dyno pull 911hp 11.5 lbs,Whipple</a>
#360
The motors look nice Rob !! I like how the fp's & filter mount to the pan that way.. The brackets may be common (?) but for some reason thats the first time I've ever seen that or payed enuff attention but either way I may have to steal that idea..
