Hustler 500efi engine tear down & Build Up
#424
Rob
Rob
#428
Rob
it would be in the injectors,i only have that one filter,im adding a 5-10 micron filter after the pump,still no water separator,
When Ive seen the rubber deteriot its been chunks,
it looks like black paint, glue and flakes
#429
Rob
getting close, ill post all the other stuff when I get a chance,the good and the bad![Drink](/forums/images/smilies/drink.gif)
The new dart gen 6 block requires a gen 4 oil filter adapter,the front ascy bolt holes are not deep enough to put the regular studs in,I had to cut the thread part about 200-.300,wasent a way to tap deeper,the water drain on the starter side is blocked by the starter,don't know who the stupid fu*k that designed that one
no provision for a knock sensor,even the non drilled bosses are in bad places,its 1/4 npt,and didn't want to drill to far to tap it deeper,so the knock sensor is shallow .Also doesn't have a port for the oil pressure gauge sensor on the side of the block like gm's gen 6,it had some on the back below the china rail,but most gen6 and 500eifs all the wiring goes across there and no way to put anything else there.hope this help someone before they getinto it.
polishing
![](http://i19.photobucket.com/albums/b177/StripPoker388/Hustler%20engine%20rebuild%20Starboard%202012/Hustler%20rebuild%20Whipple%202013/april041_zps8a338fce.jpg)
![](http://i19.photobucket.com/albums/b177/StripPoker388/Hustler%20engine%20rebuild%20Starboard%202012/Hustler%20rebuild%20Whipple%202013/engine060_zps939afb00.jpg)
![Frown](/forums/images/smilies/frown.gif)
polishing
![](http://i19.photobucket.com/albums/b177/StripPoker388/Hustler%20engine%20rebuild%20Starboard%202012/Hustler%20rebuild%20Whipple%202013/april020_zps1c6fc21a.jpg)
#430
Rob
