Hustler 500efi engine tear down & Build Up >
Old 11-17-2004, 11:45 PM
  #51
Rob
Strip Poker 388's Avatar
Default Re: Hustler 500efi engine tear down & Build Up
I need to remember to put the o ring back in it on the way back up with it
Attached Thumbnails Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-014.jpg
Strip Poker 388 is offline
Old 11-17-2004, 11:50 PM
  #52
Rob
Push rod length looks good.
Snow white is telling me to ck that injector on that cylinder Thanks for the Info Mark
3rd pick look like it was ready for a valve job
Attached Thumbnails Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-027.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-030.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-026.jpg
Old 11-18-2004, 12:00 AM
  #53
Rob
Alright on to motor # 2
Every thing came apart ok on this one ,nothing weird YET
Cross hatch
Attached Thumbnails Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-015.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-016.jpg
Old 11-18-2004, 12:10 AM
  #54
Rob
One thing about motor #1 is there was not much trash in the bearings,so somebody did a good job of cleaning it.
Not on motor # 2 it had some trash in the bearings at least they where the same name brand.the trash did look normal like most motors I have tore down.
The rear main shows a little out of round . looks like where the oil pump bolt area is.Center of top cap
The crank will definitely need to be polished on this one.
I mic every thing see if there ok
Attached Thumbnails Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-062.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-063.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-052.jpg
Old 11-18-2004, 12:18 AM
  #55
Rob
One thing I thought was weird was the scuffing on the piston skirts. they where on the same side on the piston and just on 1 3 5 7. What do yall think??
I cked the piston top ring gap, showed .032 I sure it has worn some.
t cked the ring land it .350 down just like the nitrous pistions
And guess what . the # 2 Motor had regular rings in it, so the other had gap less. There was no RPM difference in the motors at any speed , go figure
Background ck
Attached Thumbnails Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-019.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-020.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-060.jpg
Old 11-18-2004, 12:23 AM
  #56
Rob
Motor # 2 same fitting as on the other motor on the header broke ,thats weird??
Cam plug rusting, might have been a problem later on. I will paint the rear on the block on the way back up
just a few rings
Attached Thumbnails Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-039.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-041.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-066.jpg
Old 11-18-2004, 12:31 AM
  #57
Rob
Felpro 1211 gasket , looks to be too big and pushed down on the top, not good.Almost looks like they over torqued it. or the heads and block have been cut too much and pinched it?
or the rust from the top got it??
the # 1 motor had merc intake gaskets
pick 3 this pisses me off they want paint this little area so it want rust. goes for the same on the front of the block and around the oil pan
Attached Thumbnails Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-043.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-044.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-045.jpg
Old 11-18-2004, 12:35 AM
  #58
Rob
Motor #2 piston is .004 in the hole . I figure it been cut before . not much room for clean up if needed . My buddy had a BHJ tool we will ck deck height from crank center line , and ck see if deck is square
Attached Thumbnails Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-048.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-049.jpg
Old 11-18-2004, 12:40 AM
  #59
Rob
Lets have some fun , look what the bare block weights.
That hurt putting it in the back of the truck
Attached Thumbnails Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-032.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-031.jpg
Old 11-18-2004, 12:43 AM
  #60
Rob
How about these boat anchors can you see snow white looking at ya?
Thats equal to a Ice chest full of beer for Sunday
Attached Thumbnails Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-034.jpg   Hustler 500efi engine tear down & Build Up-hustler-motor-2-11-17-04-033.jpg
Quick Reply: Hustler 500efi engine tear down & Build Up
