Fuel pumps?
Charter Member #655
Fuel pumps?
I bought some cam driven water pumps for my Gen 5 454's to clean up the front of my motors so now I need to get some electric fuel pumps to replace the ones on my stock seapump. Who's would you use? Im less than 550hp and running a 800 holley.
Don
Don
If your boat has a sail do you ride a horse to the ramp?
Re: Fuel pumps?
I've had good luck with the holley black fuel pump. I did have to remove the pressure spring and stretch it a little to get the fuel pressure that I wanted, but that only took a few minutes. The black pump also has the port for a hose to the carb so it is coast guard approved.
I hate the winter!!
Re: Fuel pumps?
I just picked up a complete system from Aeromotive. I got their 11108 pump, 13207 regulator, pre-pump filter, after pump filter. I am also running an Edelbrock mechanical pump as a redundant system with a check valve to prevent back flow.
